Сontrol and display model of one of the process parameters
Hello guys. Could anyone help me? I have to create a control panel, but i don't understand how to it. There is an example in the video and screen of this program but without some elments. It would be great if someone help me.
(2,148 Views)
Hi Manax,
As a student you should know how to tackle such problems: by going through training material as offered by NI for free!
(Atleast I can read cyrillic letters to know your video is "for students"…)
So what have you tried so far? Where are you stuck?
Mind to attach your current VI?
(2,130 Views)
Hello, that's what i've tried to do, but it doesn't work well. Also i get an image of components that should be used in nodes from 1 to 5
(2,081 Views)
Hi Manax,
So you get an image (in your first message) which shows some boxes numbered from 1 to 5. And you got lists for each box (1-5) which tell you exactly which functions you need to use to replace those boxes. I didn't try to translate the description for each box, but I guess it is a good description of what is expected from you. (You might think about providing that descriptions in English as this is an English speaking forum!)
And you tried to follow those descriptions, but "it doesn't work well"!? So it works, but "not well"? In which kind of "not well"?
(Your VI is not executable, so for me it doesn't work at all…)
Do you know this forum is not intended to do your homework for you?
(2,078 Views)
Have you tried turning on "Highlight Execution"? (the light bulb) It will allow you to watch your program execute in slow motion so you can see where it is "not working well".
Former Certified LabVIEW Developer (CLD)
(2,063 Views)
