シフトレジスタ
シフトレジスタを使用して、ループ前の値と後での値を比較し、ある値以下になると終了したいのですが、ループ前の値をどのように保存すればよいかお教えください。
(2,954 Views)
Google translate:
Using a shift register, comparing the values before and after the loop, I want to end below a certain value, please tell me face How do I save the value before the loop.
Simply wire the start value through or around the loop (if i misunderstood a .vi showing the issue can be helpful).
/Y
Google'd back:
単に介して、またはループの周りの開始値式(I誤解している場合役立つことが問題示す
Qestit Systems
Certified-LabVIEW-Developer
(2,947 Views)
thank you for your information.
the vi is curve fitting. I would like to end the calculation at the point of no difference of the five life times of a reaction. The vi is a little bit complex. So I hesitate to send it to you as the attachments.
(2,941 Views)
I would like to senda part of the vi. The lowest shift-register hsould use the comparison between before and after.
I expext you may help me about it.
With my best wishes,
SunnyMyung
(2,934 Views)
Do you want to stop calculating when the 5 doubles (are they the life times?) are equal in between loops?
I imagine 2 solutions, basically the same:
- build an array connected through a shift register, compare the new with the old array (the one coming from the shift register)
- Same thing, but with all wires compared separately. (using the existing shift registers)
/Y
Qestit Systems
(2,925 Views)
