ボタンの「無効&グレー表示」色変更
いつもお世話になっております。
現在、グレー以外の色のタブ表示器にボタンを配置して使用することを考えています。
ボタンを「無効&グレー表示」にすると、添付画像のようにボタンの周囲にグレー色が
見えてしまうので色を変更して目立たなくしたいです。
自分なりに色々試してみましたが変更できず、御相談させていただきました。
お忙しいところ申し訳ありませんが、アドバイスいただけると助かります。
以上、よろしくお願いいたします。
(1,348 Views)
@sinon wrote:
I am always indebted to you.
Currently, I am thinking of placing buttons on a tab indicator of a color other than gray.
When the button is "disabled and grayed out", a gray color is displayed around the button as shown in the attached image.
I want to change the color to make it less noticeable.
I tried various things in my own way, but I couldn't change it, so I consulted with you.
Sorry for your busy schedule, but any advice would be appreciated.
Thank you for your cooperation.
You need to remove the Boolean border gray colour?
What version of LabVIEW you are using? IN LV 2023 By Default, it comes without border (Better to attach the VI instead of Image)
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(1,301 Views)
Thank you very much for your quick response.
My LabVIEW version is 2019.
And I attached the sample vi for your reference.
In the case of the button on tab, no problem happens.
But in the case of the button on a image or any object, this problem happens.
Please give me kindly advise.
Thank you and best regards.
(1,272 Views)
