回复: SSL TLS Support
Thank you very much for answering my question. Communication via transit seems to require a lot of technology and it is difficult to find routines!
Message 11 of 16
(1,753 Views)
thank you very much! In my scenario, there is an APP on the mobile phone that must use the https protocol to request the server. I have built a very simple web server with the tcp function of LabVIEW. Now it is this server. I don’t know how to build the https protocol.
Message 12 of 16
(1,750 Views)
A problem occurred when running the demo, LVTLS framework not work.
Message 13 of 16
(1,748 Views)
Can you provide the c code? thank you very much! This is my email lxlmybook@163.com
Message 14 of 16
(1,745 Views)
I've updated the LVTLS lib with the source files (no guarantee), improvements, bug fix and additional examples (GoeIP, Certificate creation, Bidirectional Interactive TLS WebSocket, etc.)
Now there is a 3rd Conditional Disable Case to support LV2020 NativeTLS, see the readme file.
See https://labview.epfl.ch, you'll find other useful OSX VIs
Message 15 of 16
(1,729 Views)
It appears that you are attempting to receive HTTPS requests over TCP but are having difficulty receiving the needed data. Here are some measures you can take to troubleshoot and perhaps solve the problem:
Check for Encryption
Use SSL/TLS Libraries
Verify Protocol Version
Inspect Received Data
Handle HTTPS Requests Properly
Debugging and Logging
Network Configuration
Consult Documentation and Examples
By following these steps and thoroughly inspecting your implementation, you should be able to detect and remedy the problem with receiving HTTPS requests over TCP. If you require additional support, please share more information about your setup and the specific issues you're experiencing.
Message 16 of 16
(1,113 Views)
