10-14-2011 01:56 AM
Thank you!!!
Thanks for your reply and kindly help~~~
Based on your suggestion, I have tried to modify my vi. However, the problems still here....
I have post two video of my vi. design.
For the <waveform Chart.mp4> video, it shows the problems of my design. The wave and the grid line keep moving.....
When I turn the switch to charge the time base of the Chart, the grid size change at the save time....Then how can I achieve the function of setting the Time/Division like a CRO??
For the <waveform Grahp.mp4> video, I have tried to replace the waveform Chart to a waveform Graph. As you can see in the video, is can show the waveform. Although I have tried to adjust the time scale in order to get a better waveform, I still display the wave....
I hope after having a look on the video, the whole picture can be more clear for you, since you do not have my hardware....
Would you mind to give me a help again? I feel really dazed and confused at this state...><
10-14-2011 02:21 AM - edited 10-14-2011 02:26 AM
this is the 4th double post for this topic, the original one is found here...
Oh, sorry, there is an even older thread for the same topic...
