04-07-2011 07:27 AM
04-07-2011 07:37 AM
I use the 1430 image acquisition card and silicon imaging1300MH-CL, the camera in MAX documents show that 300 calls per second,but while using the example of LL Ring cycle in which write-imagecontrol, second only save about 270 images, How to solve thisproblem. I use the producers, consumers structure, some of the images collected on the producers of a loop, the acquisition of theimage into an array, into the queue. Consumers about the array intowhich to save the image, but this will cause the queue increases, eventually leading to the memory run out. If you pass a reference toan image will be a problem. Ask how to solve. the problem made me crazy.
Please post here in English. Also don't create multiple posts like this. Stick to a single thread. Please continue here
http://forums.ni.com/t5/LabVIEW/pcie1430-lost-frames/td-p/1515594
