如何实现此功能?
如图所示(为省略图,每一行有很多参数,现只展示前面的部分),我想要实现一种功能:我设定第一行的参数,然后选定1,选择开始,程序就按照第一行的参数运行,同样,选择其他行就会按照其他行的参数运行,本来想用Multicolumn Listbox来实现,可是因为我每一行的每一个参数都是有设定其范围的,而且彼此之间存在约束关系,而Multicolumn Listbox好像不能实现设定里面的值吧?而且我的参数都是number形式,它的值应该是string形式的,所以我不知道是不是就不能用了。如果不行,我实在是不想在前面板上列N个numeric control控件,有没有别的控件可以实现我说的功能呢?
简单点说:我想在列表中输入参数,这个参数是有限定其取值范围和彼此关系的(同列的取值范围一样),输入完毕后,选定某一行,再选定开始键,程序就会按照该行的参数运行。
请高手指点迷津!!!
(3,355 Views)
Accepted by topic author 413332985
Hi 413332985,
  Please try to post your query in english,as you know it will be good for the members to understand and reply it fast and other members will also able to know and learn.
thanks and regards,
srikrishnaNF
Srikrishna
(3,341 Views)
It's my fault, i'm sorry for that.
Actually I wanted to post my question at NI chinese discussion forum, but i didn't konw i was in the wrong place at first, then i didn't know how to delete this question, so i'v been waiting for someone answer something that can let me close the question.
I have already got my answer at NI chinese discussion forum this morning. Sorry for everything, and i promise i won't make the same mistake anymore.
(3,326 Views)
