数据采集与保存并行运行问题
程序中有两部分:一部分是用于采集数据的,另一部分则用于保存数据。现在有一个棘手的问题,如何实现数据采集一直连续进行,而在数据采集的同时能够实现数据的保存?就相当于这两个部分能够并行运行。谢谢各位。
(3,481 Views)
"On comprend rien, c'est du chinois"... (French expression to say that we don't understand anythning to an explanation : "we don't understand, that's chinese") 🙂 Please try in english...
(3,473 Views)
Thank you for your attention. My English is not very good. My problem is how I can obtain stream to disk or save continuously. The board is PCI6110.
(3,458 Views)
How to interface to your board??
You can try producer-consumer loop or alot of other methods to collect & store data simultaneously.
(3,451 Views)
你可以参考一下下面的流盘的范例。
(3,426 Views)
