機率密度probability density
sorry我是初學者,對於元件為何設定這些數值並不了解,請教各位版友,如何進一步了解這些數字的意義.
(2,805 Views)
This VI is an example that ships with LabVIEW and there is a description in the VI properties. Did you read it?
The only thing you did was change the # of iterations from 15 to 100. (I don't know the 7.1 and 2009 versions have different defaults).
Do you have problems with the math or with the code? All the VI does is make a histogram of a series of random numbers and shows it and its integral. There's really nothing to it. 😉
(2,792 Views)
