程序运行时不定时卡死,有时卡死,有时正常,卡死后无法关闭,只能从任务管理器关闭
我的这个程序是用于做实验使用的,原先一切正常,但后来仅仅做了一点微小的改动就出现了不定期卡死的现象,再试原有的程序也会偶尔出现同样的情况。每次卡死时,必须用任务管理器才能关闭
(2,919 Views)
Hi, the Chinese characters cannot be displayed on my machine, which version of labview do you have on your computer? also are you using any NI or third-paty hardwares? Since you mentioned that after minor changes to the VIs, they led to unusual stuck while programs running and the programs can only be force closed via device manager. So what are the changes you made?
Yupeng J.
(2,913 Views)
