能否在尽可能短的时间内采集更多的数据!32个channel同时并
您好!
我使用两块PXIe 6358 Ni card 同时控制32 channel 光电倍增管(H11460 from宾松)。这些通道同时采集数据,但是要求使用尽可能短的时间。比如我设定的数据采集速率为1MHz/s ,每次抽样1000个,这能不能说我采集一次使用的时间就是1ms呢? 但是我实际测量 却是300 ms。因为我要采集上万次的数据,并且要将他们进行叠加,如果每次都要花300 ms,我采集一次实验的数据要花掉至少一天的时间。我想问一下,有没有什么办法可以提供我的采集速率? 或者把所有的数据都快速的读到一个文件,然后后续进行处理叠加他们?
希望你们的回答@谢谢!
我的数据采集部分程序截图见附件。谢谢。
(2,234 Views)
You can probably greatly improve the amount of time things take by modifying your subVI. Usually you want to take care of all configuration and place the start task for a DAQmx task before you enter a loop and then perform the read inside the loop. Since you have the start task inside a loop for each individual read your computer is sending configuration data and reserving and unreserving the device. You can find an example of how to program a continuous read on a DAQ device if you go to the example finder in LabVIEW. On the browse tab you can look under Hardware Input and Output>>DAQmx>>Analog Input and then open Voltage - Continuous Input.vi. Give that example a look and try and format your task similar to that and see if that helps.
Also for future reference, this is the English forums and you'll have a better chance of getting more users who are able to help you if you post in English. If you prefer to post in Chinese, National Instruments does have a Chinese forum which you can find here, http://forums.ni.com/ni/?category.id=ZHSForum
Hopefully that improves things for you. Have a good day.
Miles G.
Staff Applications Engineering Specialist
(2,212 Views)
