范例无法打开
大家好,我已经安装了LabVIEW Sound and vibration Toolkit,在打开某些范例仍提示“注:该范例的运行依赖于附加工具包。当前未安装所需的工具包。这是什么原因,详情可以参见我的附件截图
(1,569 Views)
(1,546 Views)
I have installed the NI-DAQmx, but I still can not open the example. Please help me.
(1,522 Views)
Accepted by topic author Tangzhi
You can search C:\Program Files (x86)\National Instruments\LabVIEW 2021\examples
for the example VI.
George Zou
(1,501 Views)
Uncheck Product Only and make sure the package "NI-DAQmx Support for LabVIEW 20xx" is listed. Sorry that I don't have DAQmx installed on my PC and I can only show you with NI-XNET.
If that package is not listed, go to the PACKAGES tab to search for it or run the NI-DAQmx installer again to install it.
https://tmesystems.net/
(1,483 Views)
Thank you for your suggestion. I have checked the package manager and the NI-DAQmx Support for LabVIEW 2021 have been installed. Attached is a screenshot.
(1,475 Views)
Oh, it is a good choice. I find the example in my local disk.  Not sure why this example can't be opened in the example manager. Anyway, thank you again.
(1,470 Views)
