陀螺儀
請問
我是利用 CompactRIO 、 RT環境下 利用NI 9205 來擷取陀螺儀的角速度資料
而陀螺儀的訊號為附件所示,而我目的是要知道角度
我希望能邊積分邊擷取訊號,亦即想在任何時間都知道目前積分到何處,則可以知道目前角度多少
(3,175 Views)
Hi,reai47
I think you would better put your posts here in English to be able to get the best solution. Translating your question in English is not too difficult for you, is it?
(3,164 Views)
English Translation (thanks to Google)
I am using a CompactRIO in a Real-Time environment using NI 9205 to retrieve the angular information from a gyroscope.
The gyroscope signal is shown in the annex (attached image), and I know the direction it is aiming to.
I would like to side edges integral to capture signals, that is, at any time I would like to know where the current points are, you can know how much the current point of view.
Message Edited by Ray.R on 05-26-2009 08:02 AM
(3,154 Views)
