랩뷰에서 다른 프로그램을 불러다 사용할수있나요?(Agilent 89600 software)
Agilent 89600 software를 랩뷰에서 불러다 사용하고자합니다.
어떤 방법이 있습니까?
(5,853 Views)
You can make a suggestion for that driver at http://www.ni.com/idnet/
We don't have any driver software for that instrument yet currently available. Possibly a customer has this code. You may want to try posting this same post in the instrument control forum and see if you get better results.
-Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(5,839 Views)
