블록다이어그램
랩뷰 버전9.0을 사용해서 현재 공부중인데,
VI를 만들면 프런트패널과 블록다이어그램 두개 창이 뜨게되고..작업후 저장해서 다시 불러 들이면
프런트패널만 뜨는데..어떻해야 블록다이러그램을 다시 불러 올 수 있나요..?
(2,928 Views)
English?
(2,923 Views)
Translated from Korean
Googe translate:
By using LabVIEW version 9.0 and trying to come here to study,
When you create a VI front panel and block diagram of two windows to be opened if they get back to you later .. jakeophu
Block peureonteupaeneolman what to do .. it rises again, and he can come do doing grams ..?
Yahoo babelfish:
Uses a lap view version 9.0 and currently is in the process of studying, Makes VI and the front panel and the block diagram cranial window make float and they become. After working stores and calls again and when admits Only the front panel floats. [e] [tteh] does and again will be able to call the block die lug RAM.?
Hmmmm.... 😉
(2,915 Views)
