01 1011 - 11 1101 = ? use 2's complement
I'm trying to figure out this doozie: 01 1011 - 11 1101
use 2's complement to solve, 6bits signed.
This is what I tried:
range of 6bits: -32 to 31
01 1011 = 27
11 1101 = -29
27 -(-29) = 56 (overflow)
11 1101 -- 2s complement --> 10 0011
so
                          01 1011
                      + 10  0011
    (missing bit)11 1110 = -2!!!
Any luck?
(4,540 Views)
Are you trying to implement this with LabVIEW ? The fixed-point functions are your friends.
(4,507 Views)
Hi Bit,
what's the problem?
And please explain how you want to represent "56" with a datatype only capable to hold values from "-32 to 31" (as you already stated)!
(4,503 Views)
You have the wrong value for b111101, which is -3:   -2^5 + 2^4 + 2^3 + 2^2 + 1 = -32 + 29  = -3
And the 2's complement of that value is 000011, not 100011, so
  01 1011  (27)
+ 00 0011 -(-3)
01 1110 (30)
You can use a 6-bit signed fixed-point control (WL=6 and IWL=6) with the radix visible to play with these values and see how it works.
(4,458 Views)
As you should have learned at some point, another way of doing subtraction is to (2's)-complement the subtrahend and add.
Do you know how to do a 2's complement?  Invert all the bits (1's complement) and add 1.
Two's complement of 11 1101 = 00 0010 + 00 0001 = 00 0011 (or decimal 3).  Notice that this means that in 6-bit, your number is -3, not -29!  This is probably the source of your frustration.
01 1011 - (11 1101) = 01 1011 + 00 0011 = 01 1100 = 30
27 - (-3) = 30
Doing the subtraction literally, starting from bit 0 -- 1 - 1 = 0 (bit 0), 1 - 0 = 1 (bit 1), 0 - 1 = 1 (bit 2, need to "borrow), 1 - 1 - 1(borrow) = 1 (bit 3, need to borrow), 1 - 1 - 1 = 1 (bit 4, need to borrow), 0 - 1 - 1 = 0 (bit 5), or 01 1100.
Bob ("Just like second grade, but missing 8 fingers") Schor
(4,449 Views)
Ahem.
I'm sure that Bob meant to say the result in binary is 01 1110
Rod
(Checks typing......)
(4,420 Views)
Oops ...
BS
(4,388 Views)
