0S and 0K when write to spreadsheet
hi i have this two thing appears wen i write to speadsheet Š and K ..Need help..thk u
Message 1 of 10
(3,972 Views)
More briefing neededSmiley Indifferent
I have still not got what I love.....
Message 2 of 10
(3,971 Views)
hi. i have a 2D array. when i use Array To Spreadsheet String. after it writes to the text file there is showing \0S and \0K at the first line. I use %s as format string and empty constant as delimeter.
Exp like tis   …*4545454 20       INSTANT.... How to remove this …
Thk u. Plz help me to solve this.
Message 3 of 10
(3,964 Views)
Ok, Which version are you using 8.0 or 8.5.
If 8.0 I think you can't directly write a string. But if 8.5 you can. I think you are using 8.5 right?
Also, use delimiter as a comma not empty constant.
Message 4 of 10
(3,962 Views)
Is it .txt or .csv or .xls file?
Message 5 of 10
(3,957 Views)
im using 8.0. how to convert using the array to spreadsheet string in this version?
 i have tried using the comma as the delimeter but not showing any result.
 i have to convert the array to  .mit format.
Thank u for ur help
Message 6 of 10
(3,947 Views)
I don't know about the .mit.Smiley Surprised
But here are the two VIs at your serviceSmiley Wink
Message 7 of 10
(3,944 Views)
"Array to spreadsheet string" is OK. I t has no changed between versions. What is the meaning of"not showing any result". Even an empty string is a "result". Please clarify.
Why don't you show us exactly what you have so far?
Message 8 of 10
(3,933 Views)
thk u got it
Message 9 of 10
(3,915 Views)
Hai,
Could u post what problem u faced and how you solved it? It will be useful for people who may face same problem and when they searched this forum.
Mathan
Message 10 of 10
(3,907 Views)
