0x6465290c
Cognex Camera System using labview as front-end for control of multiplexers has corrupted the ni software two times in the last two weeks. System has battery backup but ni software will not allow windows to shut-down so battery power fails and unscheduled windows shutdown curropts the ni drivers?? When computer is restarted the Camera application will not start and faults with the following messages.
Faulting Application  NImax.exe  Version 3.1.1.3003
Faulting Module msvert.dll Version 7.0.2600.2180
Fault address  0x00037678
The Instruction at 0x6465290c referenced memory at 0x00000000. The memory could not be read
Click OK to terminate Program.
Question #1.  Is there a way to allow automated shutdown of the system under these circumstances.
                #2.  What is the easiest way to recover from this. At present we have to call the System Integerator to come and restart app.
(2,930 Views)
Hello RodS,
It sounds like the root cause of the issue is that NI Measurement & Automation Explorer (MAX) and its database of devices, channels, and tasks in your system is becoming corrupted by improper shutdowns of your system.  Can you elaborate a little more on how NI software will not allow Windows to shutdown properly?  Addressing this issue sounds like the best way to solve to this issue.
One thing I would recommend is upgrading to the latest version of MAX and any drivers you are using to see if the instability is improved in a later version.  It looks like from the error message that you are using MAX 3.1.1.  What National Instruments hardware and drivers (versions) are you currently using?
There is one other option although we generally do not recommend doing this.  You could try to delete the 'Data' folder in the C:\Program Files\National Instruments\MAX directory.  First you will need to close all National Instruments programs and make sure that the NIMax.exe and nimxs.exe are not present in the list of processes in Windows Task Manager.  When you delete this folder, you will also delete any tasks, channels, and devices you have saved in MAX and will need to recreate these the next time you start MAX.  Because you will have to reconfigure your system, this is generally a last resort.  I would recommend working to see if this issue can be avoided with proper Windows shutdowns.
Travis G.
Application Engineering
www.ni.com/support
(2,912 Views)
