1 PPS from 6608
What functions should I use to output 1 PPS from the 6608?
(2,669 Views)
Hello lawr,
Check out this link, which has the example on using PXI-6608 to generate PPS signal. This would be a good starting point where you can modifiy the example to fit your application
Good Luck
-nAyer
(2,653 Views)
