10 bit integer
Hi all,
I have a problem with LabView. I have a 10 Bit Integer value.  The Datarange  is from  -512 to 511. How can I make that LV build the two's complement of this 10 Bit Integer value, because I only can declare a 16 Bit Integer value. I hope that somebody can help me.
Thank You!
Greetings from Germany
Juan
(4,222 Views)
I am far from being an expert in bit computing, but I think the way you should follow is to try to get an array of 10 bit, then add 6 bit at "the appropriate" place in the array so that they don't change your value.
I hope this idea will help you to find a suitable solution, good luck 😉
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(4,210 Views)
You don't really need to do anything special other than perhaps providing data coercion on your numeric controls to limit the values to [-512, 511].  To build the two's complement you can just use the following:
Message Edited by smercurio_fc on 02-21-2006 03:00 PM
(4,190 Views)
Thank you!
I try tomorrow at work and I will tell you the result!
Best regards!
(4,172 Views)
