1043 error when trying to use dynamic events on RT system
I am trying to define some dynamic events as specified it the LabView help for RT targets. But when trying to run the vi I get the 1043 error. What am I doing wrong?
Thank you,
Przemek
(2,871 Views)
Dear Przemek,
to fully understand you problem and to be able to help you, I will have to ask you a few questions:
What version of LabVIEW are you using?
What RT target are you using?
What specific help file are you referring to?
Are you creating an executable?
(2,853 Views)
HI!
I am using a PC based RT target,
LV 2010,
The help file is entitled "Using Events in LabVIEW" It is a halp file for LV 8.2 but it should work in 2010? http://zone.ni.com/reference/en-XX/help/371361B-01/lvconcepts/using_events_in_labview/
I will do some more research on this topic in the LV 2010 help and Examples.But now I need to finish another project.
Thank you for reply!
Przemek
(2,848 Views)
Dear Przemek,
you can have a look at the following examples:
http://zone.ni.com/devzone/cda/epd/p/id/4131
https://forums.ni.com/t5/Archive-TKB/Demonstration-of-Dynamic-Event-Registration-and-Queues/ta-p/350...
If you still have problems, please describe what do you want your program to do. When I run it I don't get any error, but it doesn't seem to work properly anyway.
(2,835 Views)
