1074126845 error at ag6000 Read Waveform.vi
I'm acquiring signals from a scope channel, DSO 5014 A (LXI), with a program done in LabView 8.5.I'm using a LAN cable to comunicate the scope and the computer.
The program has been run properly for a few days acquiring the signals (and in fact, now is running ok) but however, I for the last 5 hours before I couldn't running it because an error appears:
"Error -1074126845 occurred at ag6000 Read Waveform.vi, Possible reason(s):
Driver Status:  (Hex 0xBFFA2003) Maximum time exceeded before the operation completed.
Primary Error: (Hex 0xBFFF0015) Timeout expired before operation completed."
I don't understand what's going on because I didn't modified the program but yesterday it was working but not this morning.I tried to restart the computer, the scope, to swicht them off...but it didn't work!
Now is working, but I have no idea why!
Somebody could give me any idea?
(3,540 Views)
I'm not sure,but maybe there was a problem with the averaging. I decrease the burst period in the function genetor, and at least it is working properly now!
Cheers
(3,531 Views)
Hi again!
THe problem is still there!I can't understand why!
Yesterday, once I decrease the burst period, it worked well so it was measuring over night, but this morning when I arrived there was again the same problem!
I decrease the average from 256 to 16, and it works again.
But I don't know why!
About the averaging, I used an example program which was with the drivers of this scope, and the VISA session is connected to it.However, what do you suggest me?
Thank you for the help!
(3,516 Views)
Duplicate post.
Please keep your commentary in the original thread.
(3,500 Views)
