1074360293 IMAQdx timeout
I need help with this error (-1074360293 IMAQdx timeout).  This doesn't fail right away, but it runs for a while and then it fails and eventually LabVIEW will crash (close).  I if run the VI by itself no error occurs, but when I implement that into the main program it will fail.  I have windows 7 and it is updated to the latest.  I searched in the NI discussion forum and it appeared that one person has experienced this issue before and he said that he changed host controller driver to Texas Instrument (TI) HOIC compliant IEEE 1394 and system worked fine.  I don't know what is TI HOIC compliant IEEE 1394 and I don't know where to download it and how to install on my computer.  If any of you know the solution, please help me out.  Attatached is the VI that grabs images and saves to an AVI file.
Thank you very much.
(2,984 Views)
Would you mind posting a screenshot of the error you're seeing? Also, what model camera are you acquiring with?
Cheers,
Andy C.
(2,959 Views)
The problem has been found.  I was not about the recording, but it was the screen shot after the recording (this step is on a separate VI that is called after the Recording VI).  For now, i don't know what causes LabVIEW to crash, but I will run the screen capture VI alone to find out.
Thank you for your reply.
son
(2,956 Views)
I'm glad the problem looks to be resolved for now. Definitely follow up if the behavior comes back!
Cheers,
Andy C.
(2,941 Views)
