1074384895 occurred at Check Runtime Error
Hello All,
This is Shashank Kamble.
We have a following system configuration & facing the error as attached.
  1. PXI CAN CARD- 8513/2
  2. PXI OS- Windows XP
  3. LabView Version - 8.6
  4. Embedded Controller- 8105
Following is the scenario for the Error-
  1. Under NI Max we able to detect NI CAN Card.
  2. Self Test also getting PASSED for above CAN Card.
However while running BUS Monitor for CAN Port we are getting following error-
"Error-1074384895 occurred at Check Runtime Error.vi."
We tried to locate the nixnterr.log . However it wasn’t created.
Can you please guide us how we can troubleshoot this error?
Thank you in Advance!!
Shashank Kamble
(3,930 Views)
i also have the same problem, without any soluation。
(3,324 Views)
Sadly, the bad news is that the error mentioned in the title doesn't exist!  Unfortunately, the actual error, -1074384895 no longer is listed in current LabVIEW installations (I have LabVIEW 2016 through 2019 installed, and I get "This error code is undefined."
Your best bet is to contact National Instruments.  However, you are using extremely old software, including Windows XP -- the most likely solution would be to install Windows 7 (also near "end of life") or Windows 10 and a more current LabVIEW version.
Bob Schor
(3,312 Views)
Google is your friend.  Google your error code (with enclosed in quotation marks to include the negative sign) and you get lots of hits.  I can't guarantee the quality of said hits, but there is a lot of stuff for you to look at.
Bill
CLD
(Mid-Level minion.)
(3,307 Views)
