Hi!!
Some body what means this error code -1074388920?? Please help.
Regards
(3,407 Views)
My Explain Error doesn't recognize the error code.
You  might be able to get more help if you can tell us what you were doing, what kind of VI you were running, you know DETAILS.
(3,403 Views)
Error Description :
 " Overflow in the CAN communication chip. This error occurs when frames are received back-to-back for long periods.
Solutions: Set Series 2 Filter Mode to filter out frames; Dedicate entire CAN card to receive high busload (transmit
with 2nd card, receive another network with 2nd card instead and 2nd port). "
AshwiN
(3,389 Views)
