-113, "undefined header, read" error -1074000000
Hello, I am still fairly new to labview and I am writing a program to set an inputted voltage of a Yokogawa GS200  on and off at inputted. I currently also have a light that goes on and off when the voltage would be on or off as well. When I am running my code (attached below) I have an error pop up that says '-113, "undefined header, read" 0, "No error" -1074000000'. I am running labview 2015 SP1. Any help would be greatly appreciated.
(4,178 Views)
Hi Kelsey,
where does the "error pop up" appear? How does it look like?
Did you try to debug your VI? Step by step? Probes?
And please remove the classic Rube-Goldberg of "IF true THEN true ELSE false" from your VI. You implemented that one twice… 😄
(4,174 Views)
The error pops up both in the error box on my front panel as well as a pop up window (attached). I have tried to debug step by step as well as with the highlight execution tool. Could you please explain the better alternative to the if then else I was using. I am still very new to this!
Thank you so much for your help!
(4,167 Views)
Hi Kelsey,
so its an error of the Yokogawa device, reported to you by the Yokogawa driver VIs.
Check the Yokogawa manual. It will explain the error "-113". Once you know the explanation you can debug your VI to find the offending commands you send to your device…
As said before: with step-by-step debugging you will find the problem quickly!
(4,165 Views)
Generally I have found error -113 "undefined header" is most commonly a communications issue.
Either your communication settings are not correct or you're slamming commands in it too fast and overflowing an internal buffer causing it to receive corrupt commands.
=== Engineer Ambiguously ===
(4,146 Views)
Read Rube Goldberg Code
(4,137 Views)
