1172 property Node error in 2018 labview
This first screen shot has the error message in it I'm currently trying to resolve.
This second screen shot is entire view of the vi on two monitors I apologize for the appearance of it but I had to stretch the application over to different monitor screens.
I keep getting a 1172 Property Node (Arg:1) and I don't know why.  Any help with this issue would be great.
(1,602 Views)
Put a probe on the reference wire leading in to the property node that generates the error.  See if you get a null reference (0x00000000) or a real one (basically anything else).
I'm betting you'll see that it's a null reference.  If so, there's probably some sort of action you need to call on the wire there to actually start the connection before it will output a working one...
If it's not a null reference, do you maybe have some sort of example code in C# or whatever that you're working off of to create this?  Maybe you could get some?  Whatever the "ctl_LoginProcess" is probably has some documentation to it that maybe would give a hint as to something you skipped by accident.
(1,573 Views)
I tried putting a probe in there.  It is coming up null, but I still can't figure out why.
(1,538 Views)
Does anyone know if my issue with the 1172 property node error is being cause because of the Microsoft.VisualBasic version and CLR don't match.  I have the same mismatch condition for the ctl_LoginProcess as well.  The version and target CLR are different on both. If so I can I solve this issue?
(1,370 Views)
