15-20 latency seeing changes in Analog Inputs
I made a quick example:
Message 11 of 14
(892 Views)
I found this construct in an older version of the program. (See Read all available samples.JPG attached)  I believe that it does do as you say.  It has broken lines because I just dragged it out of the old VI for clarity.
I will attempt to add this to the current version and see how it goes from there.
Thank you for your detailed example.
Message 12 of 14
(888 Views)
That definitely did the trick - no perceptible latency. Many thanks to dkfire for clear response and a fine example.
The version I used is shown on the attached JPG.
Message 13 of 14
(880 Views)
Message 14 of 14
(879 Views)
