1588:Log Sync Interval can't be modified
Hi,everyone.I want to modify the value of Log Sync Interval at will,especially minimize this value.However,I find there only three choices in the screenshot,Can you help me lift this restriction?such as set this value to 100ms. Thanks a lot
(2,747 Views)
I am afraid these values cannot be modified.
(2,707 Views)
thanks for reply.I already use the  labview API to solve this issue
(2,651 Views)
Perhaps you can share your solution in this forum and mark it as solution to help other users.
(2,646 Views)
Accepted by topic author 525819liu
OK.this is my VI to solve this issue and Figure 1 shows the region in which the values are changed.
(2,643 Views)
