16 bit serial data transfer
Hello, i am working on a project in which i want to transfer 16 bits serially through RS232 to the computer. I tried many techniques but didnt got the result. Anyone here can send the solution or the Code of it.
(3,956 Views)
Hi Intelligent,
what do you want to do with those 16 bits exactly?
And what is more important, where do they come from?
Pattos
LabVIEW Gretchin
(3,954 Views)
I want to plot these data on waveform chart. Basically these will be representing a signal, which to be plotted in the chart.
I am sending them from microcontroller 8052.
thnaks
(3,952 Views)
MSB LSB MSB LSB MSB LSB MSB LSB MSB LSB MSB LSB MSB LSB MSB LSB MSB LSB MSB LSB MSB LSB MSB LSB and so on... 😉
(3,932 Views)
thnaks
Since you are Intelligent I do not want to take the joy of programming from you. But take a look at this palette. You will find many useful functions here. If you transfer the MSB and LSB in correct order you may use the cast function and cast the string directly to an array of I16 (or U16).
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,919 Views)
