16902a
Message Edited by 8845a on 03-28-2008 09:42 AM
Message 11 of 15
(1,143 Views)
Yes, firewall turned off.
I think my biggest problem is that it is not found by Max.
Message 12 of 15
(1,142 Views)
I don't think MAX has anything to do with it though it's possible that the Agilent program is using VISA. Those ActiveX emthods and properties can be run from just about anywhere. You could call them from Excel if you wanted. Just in case, you can go ahead and add the connection in MAX. Ethernet instruments are not automatically added so open MAX and right click on Devices and Interfaces. Select Create New>VISA TCP/IP Resource.
With the Agilent software, did you get any kind of instructions on how to set things up on a remote pc? I still think the problem lies  somewhere in the Agilent setup and has nothing to do with any NI software.
Message 13 of 15
(1,135 Views)
Hi!
Select Create New> VISA TCP / IP Resource. Already tried but the Max nor recognizes the IP of the instrument.
You know what can be?
Message 14 of 15
(1,127 Views)
The IP with the ping command in the command Prompt works, but does not recognize the Max, already ugasnil the firewall's machine and instrument and nothing.
Message 15 of 15
(1,126 Views)
