1D Array Of String To For-Loop
Hi fellow engineers,
I'm new to LabVIEW.
I got a question,
If I got a 1D array of string and I want to loop my program to the same number of times (Iteration) in conjunction with the numbers of sub-folders generated by the "list folder" function. How can I do it?
Any help is greatly appreciated.
(5,768 Views)
Accepted by topic author saintalan94
Wire the string array to the border of the for loop. LabVIEW will automatically iterate through each element of the array; you should not wire anything to the N terminal of the for loop. This is the default behavior for arrays entering a loop; if you do not want auto-indexing, right-click on the tunnel (where the array enters the loop) to change the behavior.
(5,765 Views)
