1D Array as Array Subset Output?
Hey guys,
I am curious if I can get a 1D Array as the Array Subset block's output?
I am trying to pull out one row of a 2D Array and even though I have the subset block coded such that the output will always be a 1D array, the data/wire type is 2D.  Is there a way I can either change that or cast it into a 1D afterwards.  This has been frustrating me for some time now and it really seems like someone should have found a work around at this point.
I am using LV8.2
I would attach a pic, but I think you guys know what I am talking about.
~milq
(3,865 Views)
@Milqman wrote:
Hey guys,
You need 'Index Array':
Tib
Message Edited by TonP on 05-29-2007 08:24 PM
My LabVIEW Ideas
(3,865 Views)
Thanks a bunch, I knew it had to be that easy.
(3,852 Views)
