1D array in memory...
Hey Jaxx, next time you come to Hollywood, we could have some Pizza and Burgers at Jaxx on Sunset while you can explain your problem directly! 😉
At the moment we have some serious language problems which prevents all of us from understanding each other.
Maybe you can explain in a few more sentences exactly what you mean by e.g. the following:
"Store in memory": Typically storing something in memory is NOT writing it to disk. Something stored in memory is no longer available after you close the program. You seem to mean "Store to disk".
"When I run the VI again": Do you mean stop the VI, then run it again without closing the front panel? Do you mean running the VI again much later, after closing LabVIEW?
"Insert into array": Do you want to insert an element or array into an existing 1D array such that the array grows by one or more elements or do you want to replace the value(s) of an existing array array element(s), keeping the array at the same size.
Pleas tell us exactly what is wrong with the posted VI suggestion, best with an example (e.g. If I run it, "A" happens. Instead I want "B" to happen, ...). You have multiple requirements, but you only tell us about solve this problem. Are some parts solved now? What is the core of your remaining problem?
What is your native language? Maybe you can ask in your language and somebody will understand and can translate. Good luck! 🙂
Message 11 of 15
(908 Views)
Hi, chilly and altenbach...
Firstly, i really wish to apologize about my language barrier... 😞
and i don't think i have to hollywood recently 😛
But no matter how, i still need you all's help(if u all understand)...
About the question that i posted at last time i think i already solved it(replace an array from 2 controls(offset3 & calibration3)into 2 indicators(offset2 & calibration2) by assign button).
But after i done that, i found a new problem here, that is when i need to replace array value from offset3 & calibration3 to offset2 & calibration2... i got to press two times for the "Assign" button for replace those array value... is it anything wrong of my program? can you all figure out?
(value of "unit" control is use to control the number element of offset2 & calibration2)
below is the vi that i modified... please take a look...
Message 12 of 15
(896 Views)
I think that this is what you were trying to build.
Chilly Charly    (aka CC)
Message 13 of 15
(890 Views)
thanks for your help... chilly... 🙂
it work very well!
with regard
Jaxx
Message 14 of 15
(884 Views)
Glad yougot to the bottom of your problem Jaxx....
Message 15 of 15
(882 Views)
