1D array of string to 1D array of numeric
I am using NI CAN to send and receive data.
The ncWriteNet.vi accepts 1D array of unusigned byte.
I have got 1D array of string. I converted decimal values to hex using number to hex decimal converter.
I need to know how i can convert 1D array of unusigned byte to D array of string.
I used the following methods
1. String to byte array.
I get a random value as 48 when the sting value is 00.
2. Type cast
I got a random value of 48 when the string value is 00.
Can I please know why do i get 48. Is there a method to convert 1D array of string to 1D array of numeric .
Message 1 of 8
(4,850 Views)
Hi Vikash,
why do i get 48.
Please read Wikipedia.
2. Type cast
You don't get a random value. you get exactly what you supply as input data!
Hint1: switch your string inputs to hex display…
Hint2: Learn about the basics of data representation! (hex display vs. normal display for strings, decimal vs. hexadecimal display mode for numerics!)
Hint3: When you have problems with your VI you should attach the VI - and not just some images of the VI…
Message 2 of 8
(4,848 Views)
@GerdW wrote:
Hi Vikash,
why do i get 48.
2. Type cast
Hint4: If you display a control/indicator/constant as anything other than its default display type, always show the radix (in case of numeric) or display type (if string).
Bill
CLD
(Mid-Level minion.)
Message 3 of 8
(4,824 Views)
Another thing that caught my attention.  You say you have an array of string and want to send it as an array of bytes over writing to CAN.  Well a CAN Frame is limited to 8 bytes.  That means your payload can only be at most 8 bytes.  If you attempt to send more than 8 bytes to ncWriteNet.vi I'm guessing it will just ignore the rest.  How do you intend on sending the remaining bytes?  What device are you talking to and how is it expecting to receive these strings?
Message 4 of 8
(4,782 Views)
I am using CAN hardware from NI and PEAK CAN
NI - USB - 8473
PEAK CAN USB FD
I am trying to transmit the data from PEAK CAN viewer via NI USB 8473 and monitor using the LabVIEW application.
PEAK CAN viewer ---> PEAK CAN USB FD (hardware) ----> NI - USB - 8473 (hardware) ----> LabVIEW software
I am transmitting only 8 bytes and using extended ID.
For example
I have 8 bytes as 1 2 3 4 5 6 7 8
bit 0 is 1 and bit 3 is 4 I would like to vary the bit 3 and 4 to different value as the program is running.
When I transmit the data from PCAN Viewer as 1 2 3 4 5 6 7 8 I receive the same message with out any issues.
I have attached a sample vi . Please have a look.
I am using a decimal input and using "number to hexadecimal string converter" to convert dec value to hex value.
When I give 10 as dec input the string output shows A which is the equivalent hex value.
But when I use Hex out array I get 41.
How will I be able to convert 41 to A again as the CAN write VI will accept only the input inform of CAN INPUT array as shown in the front panel.
https://en.wikipedia.org/wiki/ASCII
From wiki I see 41 represent Hex and the concern value on Glyph represent A. Is that the decimal 10 is converter into string A and the string value A is converter to 41 ? i don't understand.
Message 5 of 8
(4,741 Views)
Hi Vikash,
I have 8 bytes as 1 2 3 4 5 6 7 8  - bit 0 is 1 and bit 3 is 4 I would like to vary the bit 3 and 4 to different value as the program is running.
- When the values should change you need to change them at the sender (PeakCAN-View)!
- You are mixing bytes and bits!?
- How do you want to change those bits (or bytes)?
No, you don't understand…
You are mixing numeric values with ASCII strings - that is a problem to many programming beginners!
Replace NumberToHexString and StringToU8Array by a simple BuildArray node to reach your goal…
Message 6 of 8
(4,736 Views)
Below is my CAN message
$1 $2 $2 00 00 00 00 FF
Where
$1: Direction (0 - Stopped, 1 - Forwards, 2 - Backwards)
$2: Speed
For direction I can use button on the front panel and pass value of either 0,1 or 2
For speed I am planning to use dial on the front panel. I want to change the dial decimal value to hex as CAN accepts Hex data format .
Did you look at my attached VI. ?
I have used Number to Hexadecimal string function and string to byte array function as you have mentioned.
I have done for one value. If i get it right I can use array to reach my goal.
But string to byte array function did not return what I am looking for.
Message 7 of 8
(4,733 Views)
Hi Vikash,
Yes, I did.
Did you read my suggestions?
Wrong: NumberToHexString does NOT return what you are looking for!
I repeat: use BuildArray instead of all those string conversions!
Message 8 of 8
(4,730 Views)
