1D array to web service
I currently have a VI that generates and appends an excel sheet with different string values.The appending is triggered when the first value of the row changes (first column is serial number). Each row corresponds to the data collected for that serial number (first column) I have been asked to modify the code to display the same on a web service. I am completely new to the web service but what I understand is this:-
The URL should be having the latest row value either as an xml or html format.
The URL will be refreshed continuously
When a new data is appended, the URL will update with the latest value
They will see the new value and update it in their database
It would be great if I can get a little guidance on this part.
Thanks so much!
D
(3,250 Views)
When you say "display the same on a web service" do you mean show a list on the browser screen?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,198 Views)
