1D waveform for daqmx base
Hi.  I have a NI-9233 USB card I aquire with.  I am running Opensuse 10.3, Labview 8.5 and Daqmx Base 3.1.   Using DAQmxBase Read, I notice that there isn't an option for 1D Waveform, only 2D DBL, under the Analog multiple samples.  On another setup using DAQmx this option is available.  I assume this is a difference between the software.  The 1D waveform seems to include the timestamp whereas the 2D DBL does not.  Is there anyway to read the timestamp from DAQmxBase?  I could artificially write the times based on the sample rate but I am afraid these will not be precisely correct. Thanks,
Jeff
(3,138 Views)
Accepted by topic author Jeff2
Hi Jeff,
This is correct--DAQmx Base does not currently provide the option to input data as a waveform.
You will have to artificially write the times.  The waveform datatype is made up of an array of data, a t0 timestamp value (you would get this from the OS), and a delta-t (based off of your sample rate).  You would use the Build Waveform function to convert the data into the waveform type if you need to.  I hope that helps you out, let me know if you have any questions.  Thanks for posting!
-John
Message Edited by John P on 10-31-2008 11:30 AM
John Passiak
(3,110 Views)
Thanks for the reply.  This is what I had been doing and it seemed to work OK, I just wanted to make sure I wasn't missing something.  Thanks again for the post.
Jeff
(3,103 Views)
