1d array substitute
I have a 1d array and want to subsitute all negative numbers with a mark.
Whats the best and fastest way of doing this?
Thank you
Message 1 of 9
(4,413 Views)
Hi RJP,
two questions:
What kind of array (datatype)?
What kind of mark?
General algorithm:
1) do a comparison "<0" and the full array, resulting in a boolean array
2) for loop with your 1d array and the boolean array as indexing inputs: in the loop you do a replacement depending on the boolean value, autoindexing enabled for output
Message 2 of 9
(4,411 Views)
- It's a 1D Waveform(DBL)
- A mark linke "N" (For negative)
Message 3 of 9
(4,405 Views)
Hi RJP,
so you have to convert your DBL array to a string array and do the replacements in the string array. For conversion you can use "number to fractional string"...
The example shows how to do it - but you will get memory problems with very big DBL arraysSmiley Wink
Message Edited by GerdW on 02-15-2008 09:09 PM
Message 4 of 9
(4,395 Views)
I have LabVIEW 8.2, How can I open your VI which is version 8.5 ?
Message 5 of 9
(4,392 Views)
You cannot do it with a waveform if you want the data as strings.
Here's one way, starting with the Y component array of the waveform....
modify as needed. 🙂
Message Edited by altenbach on 02-15-2008 12:41 PM
Message 6 of 9
(4,386 Views)
What is that function that you used in your false case?
Message 7 of 9
(4,373 Views)
Another possibility would be to keep the output DBL and just change to NaN for negative numbers.
Just wire across the false case and use a NaN DBL diagram constant in the true case..
This would be cheaper. 😉
Message 8 of 9
(4,364 Views)
Thanks altenbach, Worked GREAT
Message 9 of 9
(4,312 Views)
