1d array to 2d array
I have got 2040000 element in a 1d array. I need to convert it into a 2d array.It should be converted in such a way that the converted 2d array should have 1700x1200 elements.
(3,048 Views)
Try using the reshape array function, you can increase the number of dimensions by dragging the bottom edge.
(3,045 Views)
