1st array reading
I am trying to read the first reading greater than 0.5 in each column of the array.
CLD Certified 2014
Message 1 of 14
(5,365 Views)
From which array: Running x and y (control), Running x and y (indicator),x when y>z 2...
JM
Message 2 of 14
(5,353 Views)
I am trying to find the x when y >z. The "X When y>z" indicator shows the updated x when y>z. I want to show the first x when y>z. From the big 2-D array (x when y> 2), I want the first in each column.
CLD Certified 2014
Message 3 of 14
(5,345 Views)
What will be the output you try to obtain at the end?
Message 4 of 14
(5,340 Views)
1st Reading Indicator array should read [7,7,7,7,7,7,7,7]. Instead it reads "x when y>z"
CLD Certified 2014
Message 5 of 14
(5,334 Views)
Accepted by topic author ADrexelDragon
Message 6 of 14
(5,327 Views)
Yes. That is exactly what I want. Thank you. Is "not a number" new to 2010? I have never seen it before.
CLD Certified 2014
Message 7 of 14
(5,316 Views)
No it was there in LV86, maybe before.
JM
Message 8 of 14
(5,311 Views)
Is there any way to do it real time?
CLD Certified 2014
Message 9 of 14
(5,309 Views)
You mean inside the while loop?
Message 10 of 14
(5,299 Views)
