2 Analog Input don't work together
thank you for your reply .. but i done this .. i can't get the other data
everytime i get the data from the first bin can't extract the other value
Message 11 of 14
(877 Views)
@El-Awny wrote:
 ( The indicator is a numeric data of 1 sensor not an array )
You answered your question right here.  If you tell the "From DDT" to convert to a single scalar value, that's all you will get.  You'll need a 1D array of scalars if you are reading 1 sample from 2 channels.
BTW, this code doesn't have two channels configured.
aputman
Message 12 of 14
(873 Views)
I can't get it.
Is there anyway to get the data from the 2 analog inputs together ?
Message 13 of 14
(852 Views)
Hi El-Awny,
open the Example Finder from LabVIEW help menu.
Look for DAQmx examples.
Choose an example explaining how to read multiple analog inputs… (like "Analog Input - Voltage and Thermocouple in a Single Task")
Isn't this the most forward way to learn about a feature in LabVIEW?
Message 14 of 14
(850 Views)
