2 array mismatch
Hello!
I got the error message "you have connected two arrays that mismatch." I deleted one element of the cluster and then got this message. I know what it means but I don't know how to fix it.
Can anyone please help me what should I do?
Thanks.
Message 1 of 25
(8,818 Views)
Hi Susanne,
in your image there are no clusters to see. Please show the full picture!
In your case structures you create 2D arrays. And you have some wires going to functions outside of image which show an error. You need to fix that error - by using correct datatypes…
Simple solution: do an Undo operation of the delete. Or use a backup with the correct cluster. Or simply put that element back into the cluster…
Why didn't you continue to ask in the German LabVIEWForum?
Message 2 of 25
(8,811 Views)
Thanks for your response. A colleague is using this forum and he recommended it to me.
Attached please find the whole VI. I need to delete "Lufttemperatur" and "Luftperiode" because it isn't preferable anymore. There I deleted these items from the cluster. When I do this, I got the error. I see that the problem is that 2D arrays are connected to 1D. I tried to fix it with Index Array but it doesn't work.
You have mentioned I need to change the datatypes. I don't know which datatypes 😞
Message 3 of 25
(8,801 Views)
Hi Susanne,
It's not the WHOLE VI - it's just a (rather bad because of paging) image of your VI BD…
Just do it! Remove the wire, delete the UnbundleByName-element and delete the BuildArray-input inside the case structures…
In your first image you create 2D array, in the second image/PDF you work with 1D arrays. So the conclusion is NOT to change the BuildArray node (or their behaviour)!
Fixing a selfmade problem by throwing more code on it will seldomly work…
While fixing that VI you could replace all those ReplaceArraySubset functions by BuildArray nodes…
A colleague is using this forum and he recommend it to me.
The LabVIEWForum is (nearly 🙂 ) as good as the NI-Forum. And you could ask your questions in German…
Message 4 of 25
(8,786 Views)
I limited one problem as you have mentioned. How can I fix the datatypes that it's working? Combining 32-bit integer with 64-bit real?
Message 5 of 25
(8,785 Views)
Hi Susanna,
right-click the BuildArray and choose "concatenate arrays" menu item…
As said before: DON'T change the BuildArray behaviour while editing your code!
In the LabVIEWForum you saw all those beginner course links in my signature. Did you take all those courses?
Message 6 of 25
(8,775 Views)
Thanks. Yes it's not the whole VI but I cannot post all VIs because of company secret. I cannot delete the Unbundle by name because the remaining "Auswahl Temp Sens" and "Auswahl W-Per1" is still necessary.
If I delete the Build Array I get the error: You have connected two arrays of differennt demensions.
I will look at your other solutions.
Yes, I read a lot about Labview but for me it's more difficult to change a huge complex Labview project than to start with a new one.... thanks"
Message 7 of 25
(8,770 Views)
Hi Susanne,
I didn't say to delete the whole UnbundleByName. Delete just the one entry you don't need anymore!
I didn't say to delete the whole BuildArray nodes…
Please read what I wrote!
Message 8 of 25
(8,767 Views)
OK. I have already deleted the unwanted elements. I have fixed the first problem. But then I don't know how to fix that I get the error that I have connected 2 arrays of different dimensions. How can I solve this?
Message 9 of 25
(8,760 Views)
See message #4 and #6…
Message 10 of 25
(8,757 Views)
