2 buttons in task bar
Hi there,
when starting my application 2 button will appear in the task bar. One
showing the caption name of my app plus icon and the other only showing
the caption name of my application w/o icon. Can somebody point my to
the reason for this behaviour and/or how to reduce it to only 1 button?
Thanks a lot
Klaus
(3,619 Views)
Sounds like you have both the VI Front Panel and the VI Block Diagram open. Both panels always open when starting a new application - as Labview assumes you will want to create a VI AND edit its block diagram. Just close the Block Diagram panel if you are not editing the code. Hope I understood your question - Good Luck, Doug
(3,619 Views)
Doug,
alas it is the "compiled" application I am speaking about, i.e. what the
user will get after he has installed the app.
There is no obvious sense for the second button (the one w/o the icon)
which appears in the task bar, since you can click on it but nothing
happens besides that it gets the focus for the time you hold the mouse
key pressed. But that's all. Very strange.
Klaus
CapeFl schrieb in im Newsbeitrag:
506500000005000000CE2A0000-986697009000@quiq.com...
(3,619 Views)
In the application ini file, place the line:
hidesystemroot=True
to remove the app button from the taskbar
Jean-Pierre Drolet
Scientech R&D
"Klaus Hoelscher" a écrit dans le message news:
3b139c47@newsgroups....
> Hi there,
> Thanks a lot
> Klaus
LabVIEW, C'est LabVIEW
(3,619 Views)
Sorry it's
hiderootwindow=True
"Jean-Pierre Drolet" a écrit dans le message
news: 3b13a943@newsgroups....
> hidesystemroot=True
> Jean-Pierre Drolet
> Scientech R&D
> > Hi there,
> > Thanks a lot
> > Klaus
(3,619 Views)
Seems promising. However, I have no idea where to find or how to create
a file named "application.ini". Please advise.
Thank you.
Klaus Hoelscher
Jean-Pierre Drolet schrieb in im
Newsbeitrag: 3b13a99d@newsgroups....
> Sorry it's
> hiderootwindow=True
message
> > hidesystemroot=True
> > Jean-Pierre Drolet
> > Scientech R&D
news:
> > > Hi there,
ar in the task bar.
One
showing
to
button?
> > > Thanks a lot
> > > Klaus
(3,619 Views)
STOP
Thank you all. I found the solution. There is a VI named INIMAKER which
can be downloaded from the NI developer site. When adding the INI
generated by this VI is added to the application when installing it and
this INI contains a section
[xyz]
hiderootwindow=true
wher xyz is the name of your app
the second button will not be visible any longer.
Thanks Jean-Pierre for pointing to the proper direction.
Klaus Hoelscher
Klaus Hoelscher schrieb in im Newsbeitrag:
> Hi there,
showing
> the reason
button?
> Thanks a lot
> Klaus
(3,619 Views)
