Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
2 channel output
2 channel output
S._LaCoursiere
Member
03-16-2005
11:09 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
How do I add two channels to an anlaog output task?
0
Kudos
Message
1
of 4
(2,909 Views)
Reply
Re: 2 channel output
Dr._Imad
Active Participant
03-16-2005
11:13 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
for the channel syntax, use
for example
Dev1/ai0:1 channels 0 thru 1
Dev1/ai0,Dev1/ai2 channels 0 and 2
0
Kudos
Message
2
of 4
(2,901 Views)
Reply
S._LaCoursiere
Member
Author
03-16-2005
12:46 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Dr. Imad
As I am new to labview I am not sure where to add channel syntax
Saul
0
Kudos
Message
3
of 4
(2,894 Views)
Reply
Dr._Imad
Active Participant
03-16-2005
01:56 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
sSe attached vi. This vi ships with labVIEW
Use the illustrated syntax for physical channels
AnalogOut Example.vi 39 KB
0
Kudos
Message
4
of 4
(2,883 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
