2 columns of spreadsheet data into indicator and into an FFT
Great  catch of this hiiden typo.  now the spreadsheet  works well for 2 columns.
Do you have any idea for linking the 'spreadsheet read vi'  to the input of the 'amplitude spectrum vi' without the 'real world vi' that is in there now ?
Message 11 of 13
(1,543 Views)
Use index array to get a given column.  Then you need to build that into a waveform so you can define the dT value that is the time between consecutive values.
Then you can wire the waveform into the FFT.
Message 12 of 13
(1,530 Views)
thanks,  I wil try this.
Message 13 of 13
(1,507 Views)
