2 front panel controls with one control on the block diagram
Hello all,
Is it possible to use 2 controls on the front panel which control the same control on the block diagram?
So to have some kind of parallel control.
Thank you in advance.
(3,455 Views)
Not that I can think of. But if you use the "event structure", you can have two controls trigger the same event, and thereby produce the required value change for your "driven" function. What, "functionally" are you attempting to do?
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,450 Views)
I want to be able to change the setting of a furnace using RS485 on two panels: one overview panel and one specific panel for the furnace.
(3,443 Views)
You can just write to both indicators.
By the way, you should check out this idea on the Idea Exchange.  If you like it, give it a Kudo.
Control Shortcuts
(3,436 Views)
I don't want to use indicators but both controls.
(3,434 Views)
Sorry, misread.  As mentioned before, use an event structure.  You can have the event structure handle both controls in the same event case.
(3,420 Views)
Accepted by topic author Bart_Aerts
(3,410 Views)
