2 hours finished the webcam program
hello 🙂 i just want to ask a question...
Can i capture an image and save it using this vi?
Message 31 of 84
(10,874 Views)
Hi toufic,
yes it is possible, but you have to add this funcionality. You have to send a windows message to capture the image. I can show you an example later.
Mike
Message 32 of 84
(10,830 Views)
Thank u mike but it'll be better if u can show me the example as soon as possible..
Best regards 🙂
Message 33 of 84
(10,812 Views)
Hi toufic,
sorry for the delay. Please see the attached example. With the "get" button you send a signal to copy the current image into a picture control. Example02 is the main vi.
Hope it helps.
Mike
Message 34 of 84
(10,786 Views)
Thank u so much Mike for ur help I really appreciate:)
Best regards and Good luck!!
Message 35 of 84
(10,770 Views)
McArthur, THIS-IS-GREAT!
Message 36 of 84
(10,450 Views)
Hi Mike S81,
I saw many thanks replies on your example, but I cannot get it work. I've installed all native software for Logitech C170 web cam, but just getting black screen without any errors instead of video. Any ideas on that? May be I've missed some driver or....? I able to get video only via web cam's software, but not into LV.
There are no NI Vision dependable VI's installed on my PC
Alex
Message 37 of 84
(10,232 Views)
Hi Alex,
which OS do you use? Which LabVIEW version? Did you get any errors?
Mike
Message 38 of 84
(10,148 Views)
Very good program....Thanks alot..!!!!
---------------- Be Good. Do Good. ---------------------
Message 39 of 84
(9,978 Views)
Hi MikeS81,
When I run your VI - I see the webcam's image in the 2nd window (see the roll of tape in the attached JPEG), but only a green blank image in the first window.  When I click 'get', it takes the picture of the green window.  Do you know how to make the roll of tape stream be in the first window?
Thanks so much!
James
Message 40 of 84
(9,843 Views)
