2^nextpow2()
Hi All,
I am using the function 2^nextpow2(L) in Matlab and now I need to use it in Labview as well. could any of you tell me how to do like this function in Labview?
many thanks
Thoalfukar
(5,532 Views)
I'm not familiar with Matlab.  Can you tell us what that function actually does in mathematical terms?
Look on the mathematics palette and I bet you can find the functions there you would need to recreate it.
(5,527 Views)
I don't believe there is any function like this in LabVIEW, but there are a ton of toolkits and one of them might have it. You can quickly google finding the next power of 2 and many algorithms will show up. Implement the one of your choice in LabVIEW.
(5,522 Views)
It is not clear from Mathworks documentation what should happen with values -1 to 1. If it should give 1, then replace epsilon constant with 1.
2^nextPow2(x)
(5,509 Views)
