2 output and 1 input VI problem
Im trying to make a  multifunction VI with 2 channel output voltage and with 1 input. Im using DAQ card to both generate and aquire signals. I want one of the output to be sweeping and  another one constant sine. I have made a VI but it is having problems. Ill attach the VI.  Ill appreciate if someone help me to solve that problems
Thank you,
Stella
(2,804 Views)
First, you could use a simple formula node, not a mathscript. It uses too much code.
Second, you should be more specific. "My vi is having problems" is not much.
Where is the problem? It helps if you demonstrate your problem in a small vi
(2,781 Views)
