2 questions on graph annotations
Graph annotationa can be deleted on Front Panel using Data Operations --> Delete all annotations.
What about the similar operation in block diagram ?
And 2nd question: is it possible to modify annotation font and font size ?
Thanks.
(4,513 Views)
Here is a solution that remove only one  annotation:
(4,504 Views)
Accepted by topic author Pavel_47
HI Pavel,
unfortunately it is not possible to change the font or font size of the annotation text. Only the color.
With your example you only delete the name of the annotation and not the annotation itself. For that you can connect a constant to the property node "AnntList".
Best,
Anna
Anna Vogl
Certified LabVIEW Developer
(4,463 Views)
Ok, thanks Anna
(4,452 Views)
